Disables a specific VRRP instance or all VRRP instances.
| vlan_name | Specifies the name of a VRRP VLAN. |
| vlan_list | VLAN list (1–4,094). |
| vridval | Specifies the VRID for the VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| vrid_list | List of virtual router IDs (1–255). |
N/A.
This disables a specific VRRP instance on the switch. If no VRRP VLAN is specified, all VRRP instances on the switch are disabled.
The following command disables all VRRP instances on the switch:
disable vrrp
VLAN and VR list options added in ExtremeXOS 22.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
